TwinTurbo.NET: Nissan 300ZX forum - If the Crank pulley is seperating, and I replace, wouldn't
Havoc300 (Chicago)
on August 20, 2011 at 3:08 PM
Those don't look like oem pulleys..
posted by 90GoldZ
on August 20, 2011 at 02:09 PM
the Crank now sit closer to the Water pump and create more rubbing issues? It looks like the pump pulley has to slide further back or up. Or the Crank has to slide out or down (which can't happen).
Accessory Belt Adjustemts.....
Havoc300 (Chicago)
09:38:23 08/20/11
Check to be certain the belts are centered their
Gordo 93TT Daytona
11:47:52 08/20/11
All belts are centered on their pulleys. The water pump
Havoc300 (Chicago)
13:15:38 08/20/11
Sorry...Here are some pics....
Havoc300 (Chicago)
13:24:39 08/20/11
90GoldZ
14:09:40 08/20/11
I had same afterthought. Are you certain the parts
Gordo 93TT Daytona
14:49:53 08/20/11
No pulleys were replaced during the 60k...
Havoc300 (Chicago)
14:59:32 08/20/11
If the Crank pulley is seperating, and I replace, wouldn't -
Havoc300 (Chicago)
15:08:55 08/20/11
Replacing the crank pulley
90GoldZ
15:41:44 08/20/11
AAHHH, Now I get it. So then, As I drive for a few minutes..
Havoc300 (Chicago)
17:28:38 08/20/11
Now you have a good excuse to get a UD/OD pulley setup. (n/m)
zellamay
21:17:16 08/20/11
Does the NA and TT share the same Crank Pulley?
Havoc300 (Chicago)
10:33:28 08/21/11
The point i was trying to get across was.....
90GoldZ
07:45:03 08/23/11
Yeah..But it's not supposed to move at all... (n/m)
90GoldZ
07:39:13 08/23/11
You may have the thick washer on the a/c idler pulley
ttz'in (NorCal)
05:24:26 08/24/11
